도움말
Dell Inspiron n5050 Display Replacement
진행 중
진행 중
해당 안내서는 작업중 입니다. 최근 변경사항을 보려면 정기적으로 새로고침하여 주십시오!
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
How to replace your broken display.
  • 작성자: Tyler
  • 난이도: 어려움
Replacing the display is difficult because there are delicate cables that need to be manipulated.
단계 1 Display  ¶
Flip laptop right side up and open
단계 1 Display  ¶
  • Flip laptop right side up and open
  • Insert flat side of spudger gently along inside of screen and screen surround.
  • Work your way around the screen carefully releasing the screen surround from the lid.
  • The screen surround is held in place by delicate plastic clips, so don't use too much force.
단계 2  ¶
Unplug the cable from the camera.
단계 2  ¶
  • Unplug the cable from the camera.
  • Unscrew the six screws attaching the display support frame to the laptop lid. Lower lid to desk.
  • The lid still has the WIFI antenna connected to it.
  • When reassembling, plug the cable to the camera first, then screw in the lid.
단계 3  ¶
Unplug the cable from the display. This cable has delicate wires that can easily break.  It is glued to the back of the display, but can be carefully peeled away. The plug is held in on the sides with two clips.  Gently pull on the each side of the cable to remove it from its connector.
단계 3  ¶
  • Unplug the cable from the display.
  • This cable has delicate wires that can easily break. It is glued to the back of the display, but can be carefully peeled away.
  • The plug is held in on the sides with two clips. Gently pull on the each side of the cable to remove it from its connector.
단계 4  ¶
For this part, it is easiest to use a magnetized screw driver. Unscrew display from display hinge/support bracket.  There are two screws on each side.
단계 4  ¶
  • For this part, it is easiest to use a magnetized screw driver.
  • Unscrew display from display hinge/support bracket. There are two screws on each side.
  • Unscrew the bottom screws first.
  • Unscrew the top screws while holding onto the screen with your other hand so it doesn't fall.
