도움말
Toshiba Satellite A85-S107 15" Hard Drive Replacement
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
전제 조건 누락
전제 조건 누락
해당 안내서는 작업 시작 방법에 대한 정보가 없습니다. 전제 조건 안내서를 만들어 주십시오!
한 단계 누락
한 단계 누락
이런! 해당 안내서는 현재 몇몇 중요한 단계가 빠져 있습니다.
This guide will demonstrate how to install the hard drive.
  • 작성자: Travis
  • 예상 시간 2 - 5 분
  • 난이도: 쉬움
Use this guide to replace or install the hard drive in your Toshiba laptop.
단계 1 Hard Drive  ¶
Flip the computer around so the battery is facing away from you.
단계 1 Hard Drive  ¶
  • Flip the computer around so the battery is facing away from you.
단계 2  ¶
Locate 5mm Philips #0 screw on hard drive cover. Remove these two 5mm Phillips #0 screws using the Phillips #0 Screwdriver.
단계 2  ¶
  • Locate 5mm Philips #0 screw on hard drive cover.
  • Remove these two 5mm Phillips #0 screws using the Phillips #0 Screwdriver.
단계 3  ¶
Insert the plastic opening tool into the tab shown and lift up to remove the lower left plate. If the hard drive panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
단계 3  ¶
  • Insert the plastic opening tool into the tab shown and lift up to remove the lower left plate.
  • If the hard drive panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
단계 4  ¶
Use plastic opening tool to lift hard drive out of case.
단계 4  ¶
  • Use plastic opening tool to lift hard drive out of case.
  • Lift the left side of the hard drive and slide it out towards the left.
  • We do not have all the required parts for this guide.
