메인 콘텐츠로 스킵하기
도움말
Disassembling ZTE Racer II Phone
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
This guide will show you how to disassemble a ZTE Racer II.
  • 작성자: Jacob
  • 예상 시간 15 - 30 분
  • 난이도: 쉬움
단계 1 Phone  ¶
Carefully prise the back cover off the phone.
단계 1 Phone  ¶
  • Carefully prise the back cover off the phone.
단계 2  ¶
Remove Battery, SIM Card, and MicroSD
단계 2  ¶
  • Remove Battery, SIM Card, and MicroSD
  • Remove the four screws located around the edge of the case. They should be very small phillips heads.
단계 3  ¶
Using a flathead screwdriver, carefully prise the black plastic away. It's held in with a series of clips, and should come away easily.
단계 3  ¶
  • Using a flathead screwdriver, carefully prise the black plastic away. It's held in with a series of clips, and should come away easily.
단계 4  ¶
Carefully remove the ribbon cable that connects the capacitive screen to the main board. You need to carefully lift the small tab, then pull the cable out.
단계 4  ¶
  • Carefully remove the ribbon cable that connects the capacitive screen to the main board. You need to carefully lift the small tab, then pull the cable out.
단계 5  ¶
Now using the flathead screwdriver, prise the plastic that makes up the front, away from the circuit board. Like the back piece, it has a series of clips around the edge, and should lift free without much effort. Now using the flathead screwdriver, prise the plastic that makes up the front, away from the circuit board. Like the back piece, it has a series of clips around the edge, and should lift free without much effort.
단계 5  ¶
  • Now using the flathead screwdriver, prise the plastic that makes up the front, away from the circuit board. Like the back piece, it has a series of clips around the edge, and should lift free without much effort.
단계 6  ¶
There you have it. Amazingly simple to take apart this phone. There you have it. Amazingly simple to take apart this phone.
단계 6  ¶
  • There you have it. Amazingly simple to take apart this phone.
