도움말
Toshiba Satellite A205-S4577 Monitor Replacement
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
Remove the monitor from the rest of the laptop.
Removing the monitor allows for replacement or inspection of the screen.
섹션
도구
단계 1 Monitor  ¶
Locate the gray wire on the right. Detach the white end by gently pulling each socket away from the other. Detach the white end by gently pulling each socket away from the other.
단계 1 Monitor  ¶
  • Locate the gray wire on the right.
  • Detach the white end by gently pulling each socket away from the other.
단계 2  ¶
On the left, locate the black and white wires with gold tips on the end. Pull up on the wires to detach them.
단계 2  ¶
  • On the left, locate the black and white wires with gold tips on the end.
  • Pull up on the wires to detach them.
단계 3  ¶
Locate the thick tan cord on the left. Slide the tan cord as shown to detach it. Slide the tan cord as shown to detach it.
단계 3  ¶
  • Locate the thick tan cord on the left.
  • Slide the tan cord as shown to detach it.
단계 4  ¶
On the right, locate the thick black wire  with the white rectangular end. Pull up on it to detach it.
단계 4  ¶
  • On the right, locate the thick black wire with the white rectangular end.
  • Pull up on it to detach it.
단계 5  ¶
Remove the four 8mm button-head screws that are located in the top right (2) and top left corners (2) of the front cover. Use a Phillips 00 Screwdriver. Remove the four 8mm button-head screws that are located in the top right (2) and top left corners (2) of the front cover. Use a Phillips 00 Screwdriver. Remove the four 8mm button-head screws that are located in the top right (2) and top left corners (2) of the front cover. Use a Phillips 00 Screwdriver.
단계 5  ¶
  • Remove the four 8mm button-head screws that are located in the top right (2) and top left corners (2) of the front cover. Use a Phillips 00 Screwdriver.
단계 6  ¶
Once all the wires are detached and screws are removed, pull up on the monitor to remove it.
단계 6  ¶
  • Once all the wires are detached and screws are removed, pull up on the monitor to remove it.
