메인 콘텐츠로 스킵하기
도움말
Disassembling Motorola Cliq Rear Casing
추천 학생 안내서
추천 학생 안내서
해당 안내서는 저희 멋진 학생들의 노력으로 만들어졌으며 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
글머리 기호!
글머리 기호!
더 나은 마크업 및 글머리 기호 색/형식 조정은 해당 안내서를 더욱 깔끔하게 만들것 입니다!
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
Remove the rear casing from your Motorola Cliq.
  • 작성자: Tony Tran
  • 예상 시간 10 - 25 분
  • 난이도: 보통
This is ONLY a prerequisite guide to remove the rear casing in the Motorola Cliq.
단계 1 Rear Casing  ¶
Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers. The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed. The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
단계 1 Rear Casing  ¶
  • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
  • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
단계 2  ¶
Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
단계 2  ¶
  • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
단계 3  ¶
Turn the phone over and slide out the keyboard. Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack. Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
단계 3  ¶
  • Turn the phone over and slide out the keyboard.
  • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
  • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
  • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
단계 4  ¶
Carefully separate the back casing from the rest of the phone.
단계 4  ¶
  • Carefully separate the back casing from the rest of the phone.
단계 5  ¶
Gently pry ZIF connector upwards using the flat end of a spudger tool. The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
단계 5  ¶
  • Gently pry ZIF connector upwards using the flat end of a spudger tool.
  • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
  • You may need adhesive to keep your power cable in place when reassembling your phone.
단계 6  ¶
Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard. The rear casing and the rest of the phone should now be completely separated. The rear casing and the rest of the phone should now be completely separated.
단계 6  ¶
  • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
  • The rear casing and the rest of the phone should now be completely separated.
