도움말
Garmin Nüvi 370 Battery Replacement
맞지 않는 전제 조건
맞지 않는 전제 조건
해당 안내서에는 적절한 전제 조건 안내서가 없습니다. 알맞는 짝을 찾거나 작성하여 맞춰주십시오!
잘게 썰기
잘게 썰기
해당 안내서의 단계들은 분할되어 전제 조건 안내서들로 만들어져야 합니다.
단계 다듬기
단계 다듬기
해당 안내서에는 불필요한 단계들이 있습니다. 단계들을 다듬어 더욱 간결하게 만들어 주십시오!
This step by step guide will show you how to dissemble your Garmin Nüvi 370 in order to access and replace the battery.
In this guide the repairer replaces the battery of the device by disassembling it to expose the motherboard, which in turn allows access to the battery.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
  • Fine Point Tweezers
  • Spudger
Estimated Duration: 10 minutes
단계 1 Battery  ¶
After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
단계 1 Battery  ¶
  • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
단계 2  ¶
Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
단계 2  ¶
  • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
단계 3  ¶
The motherboard will now freely separate from the back casing; lay it flat next to the housing. The motherboard will now freely separate from the back casing; lay it flat next to the housing.
단계 3  ¶
  • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
단계 4  ¶
Disconnect the speaker and battery from their terminals on the motherboard.  This should disconnect the motherboard completely from the back panel. It is recommended that you use tweezers or the spudger for precision.
단계 4  ¶
  • Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
  • It is recommended that you use tweezers or the spudger for precision.
단계 5  ¶
Using the flat edge of the spudger from above, gently pry the battery away from the plastic. Using the flat edge of the spudger from above, gently pry the battery away from the plastic.
단계 5  ¶
  • Using the flat edge of the spudger from above, gently pry the battery away from the plastic.
단계 6  ¶
The battery should now be completely separated from the other components.
단계 6  ¶
  • The battery should now be completely separated from the other components.
  • Insert new, functional battery.
