도움말
iHome iD95 Bottom Cover Replacement
헷갈리는 텍스트
헷갈리는 텍스트
해당 안내서의 어떤 텍스트는 헷갈리며, 중복되었거나 주제에서 벗어났습니다. 편집하여 명확하게 하여 주십시오!
This guide will help you take off the bottom cover of the iHome iD95.
  • 작성자: Vincent Chan
  • 예상 시간 30 - 45 분
  • 난이도: 보통
Replace the bottom cover to make it look new and shiny.
단계 1 Bottom Cover  ¶
Unscrew five 17 mm-length, 6 mm-head screws using a Phillips #1 screwdriver.
단계 1 Bottom Cover  ¶
  • Unscrew five 17 mm-length, 6 mm-head screws using a Phillips #1 screwdriver.
단계 2  ¶
The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force. Insert a plastic opening tool between the edge of the bottom cover and the main body.
단계 2  ¶
  • The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force.
  • Insert a plastic opening tool between the edge of the bottom cover and the main body.
  • Gently pry the bottom cover from the body. Start anywhere along the front side of the iD95 and work your way around.
  • Grip the bottom portion of the device and gently lift the front part of the bottom cover a couple centimeters up.
단계 3  ¶
Be careful not to use too much force or you might break the plastic rings holding the side panels in place. Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
단계 3  ¶
  • Be careful not to use too much force or you might break the plastic rings holding the side panels in place.
  • Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
  • The side panels have plastic rings that will need to be lifted up and off the cylinders they are placed around.
단계 4  ¶
Apply the same techniques from the previous step to remove the remaining side panel. Apply the same techniques from the previous step to remove the remaining side panel.
단계 4  ¶
  • Apply the same techniques from the previous step to remove the remaining side panel.
단계 5  ¶
Locate the two plastic clips holding the bottom and back cover together. Which clip you remove first is up to you. Rotate the device 90 degrees either left or right. Insert the flat end of a spudger horizontally between the back speaker and the back cover. Place the flat end of the spudger behind one clip and pry it open. This may take repeated attempts.
단계 5  ¶
  • Locate the two plastic clips holding the bottom and back cover together.
  • Which clip you remove first is up to you. Rotate the device 90 degrees either left or right. Insert the flat end of a spudger horizontally between the back speaker and the back cover.
  • Place the flat end of the spudger behind one clip and pry it open. This may take repeated attempts.
  • This is the hardest step because the angle is awkward and the visibility is poor. If possible, have someone hold the device or provide lighting.
  • Once a clip has been removed, hold the bottom cover open so the clip will not fall back into place. One clip remains to be removed; you are almost there!
단계 6  ¶
Use the same steps to remove the remaining clip. The bottom cover is still connected to the logic board by wiring.
단계 6  ¶
  • Use the same steps to remove the remaining clip.
  • The bottom cover is still connected to the logic board by wiring.
단계 7  ¶
Use a plastic opening tool to pry off the white zip connector joining the wires to the logic board. Don't pull the wires. Take your time using a plastic opening tool.
단계 7  ¶
  • Use a plastic opening tool to pry off the white zip connector joining the wires to the logic board.
  • Don't pull the wires. Take your time using a plastic opening tool.
