도움말
Toshiba Satellite A215 S4697 Hard Drive Replacement
추천 학생 안내서
추천 학생 안내서
해당 안내서는 저희 멋진 학생들의 노력으로 만들어졌으며 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
This guide will help you replace your hard drive.
Replacing a hard drive is a great yet simple fix. Make sure your new drive is the 2.5" laptop hard drive!
단계 1 Hard Drive  ¶
Locate the hard drive in the left hand corner, and remove the two 4mm Phillips #1 screws. Locate the hard drive in the left hand corner, and remove the two 4mm Phillips #1 screws.
단계 1 Hard Drive  ¶
  • Locate the hard drive in the left hand corner, and remove the two 4mm Phillips #1 screws.
단계 2  ¶
Using a plastic opening tool, open the compartment and remove the compartment cover. Using a plastic opening tool, open the compartment and remove the compartment cover. Using a plastic opening tool, open the compartment and remove the compartment cover.
단계 2  ¶
  • Using a plastic opening tool, open the compartment and remove the compartment cover.
단계 3  ¶
Use a pair of metal tweezers to grab the plastic pull-tab that is tucked in underneath the hard drive. Use a pair of metal tweezers to grab the plastic pull-tab that is tucked in underneath the hard drive.
단계 3  ¶
  • Use a pair of metal tweezers to grab the plastic pull-tab that is tucked in underneath the hard drive.
단계 4  ¶
Using the plastic pull-tab, carefully pull the hard drive to the left to detach it from its connector. Remove the hard drive assembly from the device. This assembly consists of the actual hard drive and the metal housing. Metal housing is necessary for the reassembly of the device.
단계 4  ¶
  • Using the plastic pull-tab, carefully pull the hard drive to the left to detach it from its connector.
  • Remove the hard drive assembly from the device.
  • This assembly consists of the actual hard drive and the metal housing. Metal housing is necessary for the reassembly of the device.
단계 5  ¶
Flip over the hard drive assembly and remove two 4mm Phillips #1 screws at the top left and right side of the hard drive housing. Flip over the hard drive assembly and remove two 4mm Phillips #1 screws at the top left and right side of the hard drive housing.
단계 5  ¶
  • Flip over the hard drive assembly and remove two 4mm Phillips #1 screws at the top left and right side of the hard drive housing.
단계 6  ¶
Carefully separate the actual hard drive from the hard drive assembly. Do not touch the hard drive's connectors.
단계 6  ¶
  • Carefully separate the actual hard drive from the hard drive assembly.
  • Do not touch the hard drive's connectors.
