도움말
Blackberry 7105t LCD Replacement
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
한 단계 누락
한 단계 누락
이런! 해당 안내서는 현재 몇몇 중요한 단계가 빠져 있습니다.
  • 작성자: CeeJay
  • 예상 시간 15 - 20 분
  • 난이도: 보통
This guide details how to remove and replace the phone's LCD screen if it has broken.
단계 1 LCD  ¶
With the screen facing you, you will be able to see a small grey plastic clip.
단계 1 LCD  ¶
  • With the screen facing you, you will be able to see a small grey plastic clip.
  • Use a plastic opening tool to unfasten the clip as shown.
단계 2  ¶
Flip the logic board over to the other side. Use a plastic opening tool unclip the top two clips shown in red, and then the bottom two clips. This releases the screen.
단계 2  ¶
  • Flip the logic board over to the other side.
  • Use a plastic opening tool unclip the top two clips shown in red, and then the bottom two clips. This releases the screen.
  • Flip logic board over and remove screen.
  • Make sure to hold the screen, it could fall after being unclipped.
단계 3  ¶
NOTE: If you are not replacing the LCD screen, move on to the next step.
단계 3  ¶
  • NOTE: If you are not replacing the LCD screen, move on to the next step.
  • After removing the original screen, keep the logic board facing you the way it was.
  • Take the new screen and slip the flexible piece of connecting circuitry under the grey plastic flap that you pried up in step 10.
  • Handle the screen carefully as it is fragile.
  • Push it gently but firmly until it does not move any further to the left, then close the grey flap.
  • After this, the screen can be pushed down and clicked back into place.
  • To reassemble the phone, reverse instructions.
