도움말
iHome iD95 Backup Battery Replacement
This guide will help you take out the backup battery in your iD95.
  • 작성자: Vincent Chan
  • 예상 시간 2 - 5 분
  • 난이도: 쉬움
Use this guide to replace a dead backup battery or remove it to prevent unwanted alarm beeping.
단계 1 Backup Battery  ¶
Before taking apart the iD95, disconnect the AC cord from the wall socket and AC adapter from the DC jack. Remove any iPods, iPhones, and iPads attached to the device.
  • Before taking apart the iD95, disconnect the AC cord from the wall socket and AC adapter from the DC jack. Remove any iPods, iPhones, and iPads attached to the device.
  • Flip over the iD95 so the bottom cover is visible and the LCD screen is facing you.
단계 2  ¶
Remove the 10 mm-length, 5 mm-head screw using a Phillips #1 screwdriver.
단계 2  ¶
  • Remove the 10 mm-length, 5 mm-head screw using a Phillips #1 screwdriver.
단계 3  ¶
Use a plastic opening tool to take out the backup battery.
단계 3  ¶
  • Use a plastic opening tool to take out the backup battery.
