메인 콘텐츠로 스킵하기
도움말
Microsoft Zune HD Lower Rear Panel Replacement
Replace your Zune HD's lower rear panel.
단계 1 Lower Rear Panel  ¶
Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel. Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
  • Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
  • Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
  • Repeat this process for the other side of the lower rear panel.
단계 2  ¶
Carefully slide the lower rear panel away from the Zune.
단계 2  ¶
  • Carefully slide the lower rear panel away from the Zune.
