도움말
LG VX5600 Camera Replacement
This guide will show you how to replace the camera on your LG VX5600 phone.
  • 작성자: Irena Tran
  • 예상 시간 20 - 30 분
  • 난이도: 보통
In order to install a new camera to your LG VX5600, you will be required to disassemble most of the top half of the phone.
섹션
단계 1 Camera  ¶
Use one hand to grasp the phone and prop the inner grey casing up.
단계 1 Camera  ¶
  • Use one hand to grasp the phone and prop the inner grey casing up.
  • Unscrew the two 3.0-mm Phillips #000 screws located at the upper left and right corners.
단계 2  ¶
Use one hand to grasp the phone and prop the grey casing up, and use your other hand to pry around the edges of the black plastic cover
단계 2  ¶
  • Use one hand to grasp the phone and prop the grey casing up, and use your other hand to pry around the edges of the black plastic cover
  • The black plastic piece is adhered with glue and two wires to the outer grey casing, so you will not be able to completely separate the plastic pieces yet.
단계 3  ¶
The vibrating motor remains attached to the external cover, so use the tweezers to grasp the vibrating motor and lift it up towards the black plastic cover around the screens. The vibrating motor is adhered with glue, so it may take some force to pry it off the outer grey cover of the phone.
단계 3  ¶
  • The vibrating motor remains attached to the external cover, so use the tweezers to grasp the vibrating motor and lift it up towards the black plastic cover around the screens.
  • The vibrating motor is adhered with glue, so it may take some force to pry it off the outer grey cover of the phone.
단계 4  ¶
Flip the phone over so that the front of the top portion is facing you.
단계 4  ¶
  • Flip the phone over so that the front of the top portion is facing you.
  • Use your hands to lift the cover up and off, removing it from the phone.
단계 5  ¶
Use your fingers to grasp the gold flex cable where it is attached to the camera.
단계 5  ¶
  • Use your fingers to grasp the gold flex cable where it is attached to the camera.
  • Use the tweezers to grasp the bottom of the connection between the flex cable and camera.
  • Slowly pull upwards with your hands until the flex cable detaches from the camera.
단계 6  ¶
Use the tweezers to lift up the detached flex cable from the camera and then use your finger to hold it back. Use the tweezers to lift the camera up and out of the phone.
단계 6  ¶
  • Use the tweezers to lift up the detached flex cable from the camera and then use your finger to hold it back.
  • Use the tweezers to lift the camera up and out of the phone.
