도움말
Texas Instruments TI BA II Plus Teardown
분해도
분해도
분해도는 device의 내부를 보여주는 정보일 뿐 분해 설명서로 사용하면 안됩니다.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
  • 작성자: VSP
Teardown of the TI BA II Plus calculator.
단계 1 Texas Instruments TI BA II Plus Teardown  ¶
The BA II Plus Professional calculator.
  • The BA II Plus Professional calculator.
단계 2  ¶
Firstly on the back cover, remove the small sticky soft cushioning material covering the recess with the screws in it. 4 of them in total. Unscrew them.
단계 2  ¶
  • Firstly on the back cover, remove the small sticky soft cushioning material covering the recess with the screws in it. 4 of them in total. Unscrew them.
단계 3  ¶
Remove the battery cover by sliding it out.
단계 3  ¶
  • Remove the battery cover by sliding it out.
단계 4  ¶
Use a flathead screwdriver to gently part the bottom and top cover at the hinge on the top.
단계 4  ¶
  • Use a flathead screwdriver to gently part the bottom and top cover at the hinge on the top.
단계 5  ¶
Removing the back cover to reveal the foil, unscrew the 4 screws holding the foil and 4 other holding the printed circuit board to the front cover.
단계 5  ¶
  • Removing the back cover to reveal the foil, unscrew the 4 screws holding the foil and 4 other holding the printed circuit board to the front cover.
단계 6  ¶
Remove the foil. Ensure all screws are off.
단계 6  ¶
  • Remove the foil. Ensure all screws are off.
단계 7  ¶
This must separate the front cover from the board. Remove the board and turn it over to view the front side with a soft black cushion cover over a smooth shinny mesh.
단계 7  ¶
  • This must separate the front cover from the board. Remove the board and turn it over to view the front side with a soft black cushion cover over a smooth shinny mesh.
단계 8  ¶
The keys should fall out of the front cover when you turn it over as well.  Thats it!!!
단계 8  ¶
  • The keys should fall out of the front cover when you turn it over as well. Thats it!!!
