메인 콘텐츠로 스킵하기
도움말
iMac Intel 27" EMC 2546 Hard Drive
단지 전제 조건
단지 전제 조건
해당 안내서는 단지 다른 안내서의 전제 조건임을 참고하시기 바랍니다.
prerequisite guide, hard drive removal
단계 1 Hard Drive  ¶
Pull straight up on the SATA data/power cable to disconnect it from the drive. Pull straight up on the SATA data/power cable to disconnect it from the drive.
단계 1 Hard Drive  ¶
  • Pull straight up on the SATA data/power cable to disconnect it from the drive.
단계 2  ¶
Remove two 7.3 mm T10 screws securing the left hard drive bracket to the rear case.
단계 2  ¶
  • Remove two 7.3 mm T10 screws securing the left hard drive bracket to the rear case.
단계 3  ¶
Grab the hard drive and left hard drive bracket together. Tilt the left side up away from the rear case, and slide the assembly to the left. Remove the hard drive and left hard drive bracket from the iMac.
단계 3  ¶
  • Grab the hard drive and left hard drive bracket together.
  • Tilt the left side up away from the rear case, and slide the assembly to the left.
  • Remove the hard drive and left hard drive bracket from the iMac.
단계 4  ¶
Remove the left hard drive bracket. Remove the left hard drive bracket.
단계 4  ¶
  • Remove the left hard drive bracket.
