메인 콘텐츠로 스킵하기
도움말
Bush Pump Riser Main Slider Replacement
Replace the riser main slider in a Bush pump.
Follow this guide to remove the riser main slider in order to repair or replace it.
단계 1 Riser Main Slider  ¶
Firmly lift the riser main slider with two hands. Use caution not to drop the riser main, as this can damage the pump cylinder.
  • Firmly lift the riser main slider with two hands.
  • Use caution not to drop the riser main, as this can damage the pump cylinder.
단계 2  ¶
Use a pipe wrench to fully loosen the above grade riser pipe. Use a pipe wrench to fully loosen the above grade riser pipe. Use a pipe wrench to fully loosen the above grade riser pipe.
단계 2  ¶
  • Use a pipe wrench to fully loosen the above grade riser pipe.
단계 3  ¶
Lift the slider and riser main pipe. Place a pump rod clamp around the rod, and tighten it securely against the pump rod. Carefully lower the riser main and slider to allow it to rest on the rod clamp.
단계 3  ¶
  • Lift the slider and riser main pipe.
  • Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
  • Carefully lower the riser main and slider to allow it to rest on the rod clamp.
단계 4  ¶
Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider. Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider. Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider.
단계 4  ¶
  • Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider.
단계 5  ¶
Remove the riser main slider, and inspect it for wear and tear. Set the slider in a sanitary place to prevent contamination.
단계 5  ¶
  • Remove the riser main slider, and inspect it for wear and tear.
  • Set the slider in a sanitary place to prevent contamination.
