메인 콘텐츠로 스킵하기
도움말
Bush Pump Traveling Valve Replacement
Replace the traveling valve.
Follow this guide to remove and disassemble the traveling valve. You can then inspect or replace the valve, itself, or any of its components.
섹션 (계속)
단계 1 Traveling Valve  ¶
Insert a wrench into the slots located at the bottom of the traveling valve. Using another wrench for leverage, unscrew the valve off the pump rod. Using another wrench for leverage, unscrew the valve off the pump rod.
  • Insert a wrench into the slots located at the bottom of the traveling valve.
  • Using another wrench for leverage, unscrew the valve off the pump rod.
단계 2  ¶
Unscrew the valve from the pump rod. Unscrew the valve from the pump rod.
단계 2  ¶
  • Unscrew the valve from the pump rod.
단계 3  ¶
Be careful to keep the valve parts off the ground. Check the valve components for signs of wear and tear. Check the valve components for signs of wear and tear.
단계 3  ¶
  • Be careful to keep the valve parts off the ground.
  • Check the valve components for signs of wear and tear.
단계 4  ¶
Remove the poppet from the valve to check for signs of wear. Be sure to take note of the order and direction of the components for reassembly. This is essential, as the pump will not work if the valve is not reinstalled correctly.
단계 4  ¶
  • Remove the poppet from the valve to check for signs of wear.
  • Be sure to take note of the order and direction of the components for reassembly. This is essential, as the pump will not work if the valve is not reinstalled correctly.
