메인 콘텐츠로 스킵하기
도움말
기술: Repairing OxyCom Cabin 400 Fresh Air Unit
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
더 많은 이미지가 필요함
더 많은 이미지가 필요함
몇몇 추가 이미지는 해당 안내서의 절차를 아주 명백하게 만들 것입니다.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
This guide is used to help increase the efficiency of your fresh air unit.
Oxycom Cabin 400 uses water to cool down the cabin of a camper, mobile home, or caravan. When the efficiency is low, it can be repaired. This guide will demonstrate how to properly repair your Oxycom Cabin 400.
단계 1 Preperation  ¶
Switch off the unit and remove the top cover of the Oxycom. There will be 6 screws; remove them.
단계 1 Preperation  ¶
  • Switch off the unit and remove the top cover of the Oxycom. There will be 6 screws; remove them.
단계 2  ¶
없는 이미지
단계 2  ¶
  • You will see the thermal block covered with translucent plastic. See how many black sprinklers are loose inside the plastic cover. There are 4 sprinklers in total (about 3 cm diameter round, usually connected to white round plugs with pipes). Normally all four fall down as this is a factory fault in Oxycom Cabin 400.
단계 3  ¶
없는 이미지
단계 3  ¶
  • Cut two sides of the plastic cover with a sharp knife. Collect all sprinklers through that hole.
  • Beware of sharp edges on the plastic.
단계 4  ¶
없는 이미지
단계 4  ¶
  • Apply one drop of Super Glue to the side of the "pipe" on the sprinkler and reinstall it into the white plug by pressing it in. Do the same to all of the loose sprinklers.
  • There are metal "supports" located inside as well. Put them back in any chosen place. No need to put them under the sprinklers because there are additional round places for them.
단계 5  ¶
없는 이미지
단계 5  ¶
  • Use silicone to seal the plastic. Use duct tape over silicone to ensure that the plastic will be kept in the proper position. Leave that tape inside.
  • Replace the cover.
단계 6 Cleaning thermal unit surfaces.  ¶
없는 이미지
  • Mix 100g of powdered citric acid with 4 liters of warm water.
  • Ensure that the water reservoir is empty.
  • Pour the solution into the water reservoir.
  • Start the unit, set it to max cooling and max speed.
  • After setting to max speed and max cooling press ON/OFF and COOL buttons quickly at the same time and hold for 5 seconds until a beep is heard.
단계 7  ¶
없는 이미지
단계 7  ¶
  • Let the unit run for 1 hour. Then turn it off and drain the solution from reservoir.
  • The drained solution will contain sediments and the thermal converter will be cleaned.
  • This procedure should be repeated once a year. Now you can fully use the functional and effective Oxycom Cabin 400.
