도움말
Samsung Galaxy Note Midframe Replacement
Replace the midframe from your Samsung Galaxy Note.
Use this guide to remove or replace your Galaxy Note's midframe.
섹션
단계 1 Midframe  ¶
Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
단계 1 Midframe  ¶
  • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
단계 2  ¶
Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry. Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
단계 2  ¶
  • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
단계 3  ¶
Slide the plastic opening tool down the seam. Slide the plastic opening tool down the seam. Slide the plastic opening tool down the seam.
단계 3  ¶
  • Slide the plastic opening tool down the seam.
단계 4  ¶
Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly. Slide the opening tool along the top edge of the phone. Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
단계 4  ¶
  • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
  • Slide the opening tool along the top edge of the phone.
  • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
단계 5  ¶
Remove the midframe from the display assembly. Remove the midframe from the display assembly.
단계 5  ¶
  • Remove the midframe from the display assembly.
