메인 콘텐츠로 스킵하기
도움말
Samsung Galaxy S4 Display Assembly Replacement
추천 가이드
추천 가이드
해당 안내서는 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
Replace the front panel display assembly on a Samsung Galaxy S4.
  • 작성자: Sam Goldheart
  • 예상 시간 1 - 3 시간
  • 난이도: 보통
Use this guide to replace your Samsung Galaxy S4 display assembly.
단계 1 Display Assembly  ¶
If present, remove the 2.4 mm PH #00 screw securing the upper display assembly bracket. Remove the upper display assembly bracket from the display.
  • If present, remove the 2.4 mm PH #00 screw securing the upper display assembly bracket.
  • Remove the upper display assembly bracket from the display.
단계 2  ¶
Remove the front-facing camera from the display assembly.
단계 2  ¶
  • Remove the front-facing camera from the display assembly.
단계 3  ¶
Remove the earpiece speaker assembly from the display assembly.
단계 3  ¶
  • Remove the earpiece speaker assembly from the display assembly.
단계 4  ¶
Insert the tip of a spudger under the vibrator to free it from the adhesive holding it to the display assembly. Be careful not to immediately remove the vibrator, as its cable is also adhered to the rear of the display assembly. Use the tip of a spudger to pry the vibrator cable up from the display assembly.
단계 4  ¶
  • Insert the tip of a spudger under the vibrator to free it from the adhesive holding it to the display assembly.
  • Be careful not to immediately remove the vibrator, as its cable is also adhered to the rear of the display assembly.
  • Use the tip of a spudger to pry the vibrator cable up from the display assembly.
  • Heat works as a great "persuader" here to soften the adhesive. Liberal application of heat from a heat gun will soften the adhesive. If you pry carefully, you can save and re-use the adhesive.
단계 5  ¶
Remove the vibrator from the rear of the display assembly.
단계 5  ¶
  • Remove the vibrator from the rear of the display assembly.
단계 6  ¶
Gently insert the point of a spudger between the USB port and the USB port bracket to pry one side of the bracket off of its post. Gently insert the point of a spudger between the USB port and the USB port bracket to pry one side of the bracket off of its post.
단계 6  ¶
  • Gently insert the point of a spudger between the USB port and the USB port bracket to pry one side of the bracket off of its post.
단계 7  ¶
Remove the USB port bracket from the USB port.
단계 7  ¶
  • Remove the USB port bracket from the USB port.
  • The bracket is slightly springy and should pop back into place on the two screw posts during reassembly.
단계 8  ¶
Disconnect the soft button cable from the USB board cable. Be extra careful here, once you have removed the cable, carefully peel it away from the USB board Disconnect the antenna connector cable from the USB board.
단계 8  ¶
  • Disconnect the soft button cable from the USB board cable. Be extra careful here, once you have removed the cable, carefully peel it away from the USB board
  • Disconnect the antenna connector cable from the USB board.
단계 9  ¶
The USB board is secured to the display assembly with light adhesive. Gently insert the flat end of a spudger beneath the USB board to free it from the adhesive holding it in place. Go slow and be careful not to bend the board.
단계 9  ¶
  • The USB board is secured to the display assembly with light adhesive.
  • Gently insert the flat end of a spudger beneath the USB board to free it from the adhesive holding it in place.
  • Go slow and be careful not to bend the board.
단계 10  ¶
Remove the USB board from the display assembly.
단계 10  ¶
  • Remove the USB board from the display assembly.
단계 11  ¶
Peel up and remove the antenna connector cable from its channel in the rear of the display assembly. Other carrier models may have an additional antenna cable on the opposite side of the phone. Remove this antenna from the display assembly as well. On reassembly, it will be helpful to reinstall the USB board first, and reconnect the antenna connector cable before routing it back into its channel.
단계 11  ¶
  • Peel up and remove the antenna connector cable from its channel in the rear of the display assembly.
  • Other carrier models may have an additional antenna cable on the opposite side of the phone. Remove this antenna from the display assembly as well.
  • On reassembly, it will be helpful to reinstall the USB board first, and reconnect the antenna connector cable before routing it back into its channel.
