메인 콘텐츠로 스킵하기
도움말
iBook G4 12" 800 MHz-1.2 GHz RJ-11 Board Replacement
  • 작성자: iRobot
  • 난이도: 어려움
The standard telephone jack port for connecting to the 56k internal modem.
단계 1 RJ-11 Board  ¶
Remove the single Phillips screw securing the EMI finger to the metal framework.
단계 1 RJ-11 Board  ¶
  • Remove the single Phillips screw securing the EMI finger to the metal framework.
  • The screw goes into the hole between the modem and ethernet ports.
  • Lift the silver EMI finger off of the metal framework.
단계 2  ¶
Disconnect the RJ-11 cable from the modem.
단계 2  ¶
  • Disconnect the RJ-11 cable from the modem.
단계 3  ¶
Wedge a spudger between the RJ-11 board and the metal framework and slide the board off of the logic board.
단계 3  ¶
  • Wedge a spudger between the RJ-11 board and the metal framework and slide the board off of the logic board.
