도움말
iPad Mini Wi-Fi Rear Facing Camera Replacement
Replace the Rear Facing Camera in your iPad Mini Wi-Fi.
Use this guide to replace the rear facing camera.
단계 1 Rear Facing Camera  ¶
Pry the rear-facing camera connector up out of its socket on the logic board. Pry the rear-facing camera connector up out of its socket on the logic board.
  • Pry the rear-facing camera connector up out of its socket on the logic board.
단계 2  ¶
Insert the edge of a plastic opening tool into the crack beneath the metal bezel on the rear-facing camera. Gently pry the camera and bezel up from the rear case.
단계 2  ¶
  • Insert the edge of a plastic opening tool into the crack beneath the metal bezel on the rear-facing camera.
  • Gently pry the camera and bezel up from the rear case.
단계 3  ¶
Remove the rear-facing camera from the iPad.
단계 3  ¶
  • Remove the rear-facing camera from the iPad.
