도움말
iPad Mini Wi-Fi Logic Board Replacement
Replace the Logic Board and Lightning port in your iPad Mini Wi-Fi.
Use this guide to replace the logic board and Lightning port. The Lightning port is soldered on to the logic board and the two must be replaced as a unit.
단계 1 Logic Board  ¶
Reheat the iOpener in the microwave for one minute.
단계 1 Logic Board  ¶
  • Reheat the iOpener in the microwave for one minute.
  • Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than one minute.
  • Place the heated iOpener on the left side of the back of the iPad. Let it sit there for 90 seconds to soften the logic board adhesive.
단계 2  ¶
Slide the flat end of a spudger underneath the Lightning port cable, freeing it from the adhesive securing it to the rear case. Slide the flat end of a spudger underneath the Lightning port cable, freeing it from the adhesive securing it to the rear case.
단계 2  ¶
  • Slide the flat end of a spudger underneath the Lightning port cable, freeing it from the adhesive securing it to the rear case.
단계 3  ¶
Continue to carefully slide the spudger under the Lightning port cable nearest the logic board. Be sure to work slowly; jerking the spudger may tear the Lightning cable from the logic board.
단계 3  ¶
  • Continue to carefully slide the spudger under the Lightning port cable nearest the logic board.
  • Be sure to work slowly; jerking the spudger may tear the Lightning cable from the logic board.
단계 4  ¶
In the following steps you will be prying under the logic board. Be careful to pry evenly to avoid bending or stressing the logic board. If it is hard to insert the spudger, reheat and reapply the iOpener. Gently insert the flat end of a spudger underneath the logic board nearest the front-facing camera. Slowly pry to free the corner from adhesive.
단계 4  ¶
  • In the following steps you will be prying under the logic board. Be careful to pry evenly to avoid bending or stressing the logic board. If it is hard to insert the spudger, reheat and reapply the iOpener.
  • Gently insert the flat end of a spudger underneath the logic board nearest the front-facing camera. Slowly pry to free the corner from adhesive.
단계 5  ¶
Insert the flat end of a spudger underneath the center of the logic board. Slowly pry to free the section from adhesive. Insert the flat end of a spudger underneath the center of the logic board. Slowly pry to free the section from adhesive.
단계 5  ¶
  • Insert the flat end of a spudger underneath the center of the logic board. Slowly pry to free the section from adhesive.
단계 6  ¶
Insert the spudger underneath the logic board nearest the Lightning port cable and pry to free the corner. Insert the spudger underneath the logic board nearest the Lightning port cable and pry to free the corner.
단계 6  ¶
  • Insert the spudger underneath the logic board nearest the Lightning port cable and pry to free the corner.
단계 7  ¶
Insert the spudger further under the logic board and slide along its length to detach the last of the adhesive. Insert the spudger further under the logic board and slide along its length to detach the last of the adhesive. Insert the spudger further under the logic board and slide along its length to detach the last of the adhesive.
단계 7  ¶
  • Insert the spudger further under the logic board and slide along its length to detach the last of the adhesive.
단계 8  ¶
Lift the end of the logic board nearest the front-facing camera to ensure it is free of adhesive. Again, be careful not to bend or stress the logic board—make certain that you have cleared all of the adhesive with the spudger.
단계 8  ¶
  • Lift the end of the logic board nearest the front-facing camera to ensure it is free of adhesive.
  • Again, be careful not to bend or stress the logic board—make certain that you have cleared all of the adhesive with the spudger.
단계 9  ¶
Lift the logic board and Lightning cable assembly up and pull toward the top of the iPad to remove the Lightning connector from its housing. Lift the logic board and Lightning cable assembly up and pull toward the top of the iPad to remove the Lightning connector from its housing.
단계 9  ¶
  • Lift the logic board and Lightning cable assembly up and pull toward the top of the iPad to remove the Lightning connector from its housing.
