메인 콘텐츠로 스킵하기
도움말
iMac Intel 21.5" EMC 2308 Camera Board Replacement
Replace a broken camera board to regain iSight functionality.
단계 1 Camera Board  ¶
Remove the two 5.2 mm shouldered T10 Torx screws securing the camera board to the outer case.
단계 1 Camera Board  ¶
  • Remove the two 5.2 mm shouldered T10 Torx screws securing the camera board to the outer case.
단계 2  ¶
Lift the camera board out of the outer case, minding the cable attaching it to the logic board.
단계 2  ¶
  • Lift the camera board out of the outer case, minding the cable attaching it to the logic board.
  • Disconnect the camera board by pulling its connector away from the socket on the camera board.
  • Before reinstallation, be sure that the thermal putty applied to the camera's heat sink is thick enough to make contact with the outer case.
