메인 콘텐츠로 스킵하기
도움말
Samsung SCH-A950 Speakers Replacement
  • 작성자: Ashley Parry
  • 예상 시간 5 - 10 분
  • 난이도: 보통
This guide will teach you how to remove your Samsung SCH-A950's speakers.
섹션
단계 1 Speakers  ¶
Use tweezers to peel back the sticker on the backside of the speaker to reveal a screw that holds the speaker in place. Using a phillips #00 screwdriver, remove the screw holding the speaker. On each side.
단계 1 Speakers  ¶
  • Use tweezers to peel back the sticker on the backside of the speaker to reveal a screw that holds the speaker in place.
  • Using a phillips #00 screwdriver, remove the screw holding the speaker. On each side.
단계 2  ¶
Using the tweezers, grasp the plastic connector that connects the speaker to the logic board and pull the connector off of the logic board.
단계 2  ¶
  • Using the tweezers, grasp the plastic connector that connects the speaker to the logic board and pull the connector off of the logic board.
단계 3  ¶
Push the speaker out of the phone using the spudger.
단계 3  ¶
  • Push the speaker out of the phone using the spudger.
단계 4  ¶
Remove the speaker from the decorative housing by pulling on the wires.
단계 4  ¶
  • Remove the speaker from the decorative housing by pulling on the wires.
  • The speaker can be replaced if needed.
