메인 콘텐츠로 스킵하기
도움말
iPad 4 Wi-Fi Front Panel Assembly Replacement
단지 전제 조건
단지 전제 조건
해당 안내서는 단지 다른 안내서의 전제 조건임을 참고하시기 바랍니다.
Replace the Front Panel Assembly in your iPad 4 Wi-Fi.
Use this guide to replace the front glass panel assembly.
단계 1 Front Panel Assembly  ¶
If present, remove the piece of electrical tape covering the Wi-Fi antenna, speaker cable, and home button ribbon cable. If present, remove the piece of electrical tape covering the Wi-Fi antenna, speaker cable, and home button ribbon cable.
  • If present, remove the piece of electrical tape covering the Wi-Fi antenna, speaker cable, and home button ribbon cable.
단계 2  ¶
Flip up the retaining flap on the home button ribbon cable ZIF connector. Flip up the retaining flap on the home button ribbon cable ZIF connector.
단계 2  ¶
  • Flip up the retaining flap on the home button ribbon cable ZIF connector.
단계 3  ¶
Use a pair of tweezers to pull the home button ribbon cable straight out of its socket on the logic board. Use a pair of tweezers to pull the home button ribbon cable straight out of its socket on the logic board.
단계 3  ¶
  • Use a pair of tweezers to pull the home button ribbon cable straight out of its socket on the logic board.
단계 4  ¶
De-route the home button ribbon cable from its recess in the rear case.
단계 4  ¶
  • De-route the home button ribbon cable from its recess in the rear case.
단계 5  ¶
Use a pair of tweezers to peel back the piece of tape that secures the digitizer ribbon cable to the logic board.
단계 5  ¶
  • Use a pair of tweezers to peel back the piece of tape that secures the digitizer ribbon cable to the logic board.
단계 6  ¶
Flip up the retaining flap on both of the digitizer ribbon cable ZIF connectors. Flip up the retaining flap on both of the digitizer ribbon cable ZIF connectors. Flip up the retaining flap on both of the digitizer ribbon cable ZIF connectors.
단계 6  ¶
  • Flip up the retaining flap on both of the digitizer ribbon cable ZIF connectors.
단계 7  ¶
Use the flat end of a spudger to loosen the adhesive underneath the digitizer ribbon cable. Pull the digitizer ribbon cable straight out of its sockets on the logic board.
단계 7  ¶
  • Use the flat end of a spudger to loosen the adhesive underneath the digitizer ribbon cable.
  • Pull the digitizer ribbon cable straight out of its sockets on the logic board.
단계 8  ¶
Peel back the digitizer ribbon cable and use the flat end of a spudger to release the adhesive securing the cable to the rear aluminum case. Peel back the digitizer ribbon cable and use the flat end of a spudger to release the adhesive securing the cable to the rear aluminum case.
단계 8  ¶
  • Peel back the digitizer ribbon cable and use the flat end of a spudger to release the adhesive securing the cable to the rear aluminum case.
단계 9  ¶
Using your fingers, pull the digitizer ribbon cable out of its recess in the aluminum frame.
단계 9  ¶
  • Using your fingers, pull the digitizer ribbon cable out of its recess in the aluminum frame.
  • Remove the front panel from the iPad.
