메인 콘텐츠로 스킵하기
도움말
iMac Intel 21.5" EMC 2308 Optical Drive Fan Replacement
Replace a burned-out optical drive fan to keep temperatures down.
섹션
단계 1 Optical Drive Fan  ¶
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
  • Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
단계 2  ¶
Pull the optical drive off the pins attached to the outer case.
단계 2  ¶
  • Pull the optical drive off the pins attached to the outer case.
단계 3  ¶
Pull the optical drive fan connector away from its socket on the logic board.
단계 3  ¶
  • Pull the optical drive fan connector away from its socket on the logic board.
  • Remove the optical drive fan from the iMac.
