메인 콘텐츠로 스킵하기
도움말
Samsung Galaxy Tab 10.1 Motherboard Replacement
Use this guide to help you replace a damaged or malfunctioning motherboard.
  • 작성자: Davie Sy
  • 예상 시간 30 분
  • 난이도: 보통
In this guide, you will learn how to replace the motherboard on your Samsung Galaxy Tab 10.1. A faulty motherboard can lead to a multitude of performance issues, especially if your device doesn't turn on at all. There are a couple prerequisites we need to get out of the way first!
단계 1 Volume and Power Button  ¶
Hold down the motherboard with your finger and use a spudger to gently pry up the connection for the volume keys and power key.
  • Hold down the motherboard with your finger and use a spudger to gently pry up the connection for the volume keys and power key.
단계 2 Flash and Rear Camera Connection  ¶
Using  the flat end of a spudger, disconnect the black flash cable connector from the motherboard. Disconnect the white rear-facing camera connector.
  • Using the flat end of a spudger, disconnect the black flash cable connector from the motherboard.
  • Disconnect the white rear-facing camera connector.
단계 3 Front Camera, Micro SD card/headphone Connection  ¶
Use the flat end of a spudger to disconnect the orange front-facing camera connector. Disconnect the blue Micro SD card/headphone jack connector from its socket on the motherboard.
  • Use the flat end of a spudger to disconnect the orange front-facing camera connector.
  • Disconnect the blue Micro SD card/headphone jack connector from its socket on the motherboard.
단계 4 Speakers and Antenna Connection  ¶
Using the flat end of a spudger, disconnect the orange speaker connectors for the left and right speakers. Disconnect the gold antenna cable connector from its socket on the motherboard. Disconnect the gold antenna cable connector from its socket on the motherboard.
  • Using the flat end of a spudger, disconnect the orange speaker connectors for the left and right speakers.
  • Disconnect the gold antenna cable connector from its socket on the motherboard.
단계 5 Motherboard Removal  ¶
Lifting from the bottom edge, gently remove the motherboard. Lifting from the bottom edge, gently remove the motherboard.
  • Lifting from the bottom edge, gently remove the motherboard.
