도움말
Alienware M14xR2 Optical Drive Replacement
This guide will teach you how to remove the optical drive.
  • 작성자: Jordan Ramsey
  • 예상 시간 2 - 4 분
  • 난이도: 아주 쉬움
This guide will show you how to safely remove the optical drive from the laptop. In order to remove the optical drive you first need to remove the battery.
단계 1 Optical Drive  ¶
Unscrew the four 6.35 mm size 1 screws. Pull up on the end of the orange tab to detach it from the white connector. Lift the optical drive up and out of the laptop and set it aside.
  • Unscrew the four 6.35 mm size 1 screws.
  • Pull up on the end of the orange tab to detach it from the white connector.
  • Lift the optical drive up and out of the laptop and set it aside.
