도움말
Toshiba NB205 N330PK Speaker Removal
일관성 없는 이미지
일관성 없는 이미지
해당 안내서의 이미지를 전제 조건들과 더욱 일관성 있게 업데이트하는 것은 안내서의 멋짐이 향상될 것입니다.
마크업 사고
마크업 사고
해당 안내서는 더 나은 마크업이 필요합니다. 일부 마크업 주석의 편집 또는 작성을 도와주십시오!
글머리 기호!
글머리 기호!
더 나은 마크업 및 글머리 기호 색/형식 조정은 해당 안내서를 더욱 깔끔하게 만들것 입니다!
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
This lengthy guide outlines how to remove a non-functioning speaker inside the netbook.
단계 1 Speaker  ¶
Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body. Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body. Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
단계 1 Speaker  ¶
  • Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
단계 2  ¶
Reach under the keyboard and disconnect the electrical connection. Lift the keyboard assembly out and away from the netbook.
단계 2  ¶
  • Reach under the keyboard and disconnect the electrical connection.
  • Lift the keyboard assembly out and away from the netbook.
단계 3  ¶
Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool. Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool.
단계 3  ¶
  • Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool.
단계 4  ¶
Remove this electrical connection with tweezers. Use a spudger to gently pry the bezel from retaining clips.
단계 4  ¶
  • Remove this electrical connection with tweezers.
  • Use a spudger to gently pry the bezel from retaining clips.
  • This will allow the keyboard bezel to lift off of the body.
단계 5  ¶
Use tweezers to remove the electrical connection to the old speaker assembly.
단계 5  ¶
  • Use tweezers to remove the electrical connection to the old speaker assembly.
단계 6  ¶
Use a bit driver and a Phillips #0 bit to remove the two retaining screws on the speaker assembly. Lift out the old speaker assembly.
단계 6  ¶
  • Use a bit driver and a Phillips #0 bit to remove the two retaining screws on the speaker assembly.
  • Lift out the old speaker assembly.
