메인 콘텐츠로 스킵하기
도움말
LG CU515 SKU 64743 Device Mother Board Replacement
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
진행 중
진행 중
해당 안내서는 작업중 입니다. 최근 변경사항을 보려면 정기적으로 새로고침하여 주십시오!
잘못된 도구
잘못된 도구
이미지 및/또는 텍스트의 올바른 도구를 사용하여 해당 안내서를 더 효과적으로 만들어 주십시오.
This guide will use step-by-step instructions and pictures to show how to replace the motherboard of the LG CU515 SKU.
  • 작성자: Maggie
  • 예상 시간 15 - 30 분
  • 난이도: 보통
This guide explains how to remove the motherboard. This is a fairly difficult guide for the LG CU515 SKU 64743 Device. Removing the motherboard will require many tools and steps. However, this guide will take you through each step in detail so as to make the process as easy as possible.
섹션
단계 1 Mother Board  ¶
Using a spudger or other sharp tool, remove the two rubber pieces on the top of the back of the phone. Using a spudger or other sharp tool, remove the two rubber pieces on the top of the back of the phone. Using a spudger or other sharp tool, remove the two rubber pieces on the top of the back of the phone.
단계 1 Mother Board  ¶
  • Using a spudger or other sharp tool, remove the two rubber pieces on the top of the back of the phone.
단계 2  ¶
Use a small Phillips head screwdriver to remove the six 3mm screws identified in the photo. Use a small Phillips head screwdriver to remove the six 3mm screws identified in the photo.
단계 2  ¶
  • Use a small Phillips head screwdriver to remove the six 3mm screws identified in the photo.
단계 3  ¶
Using a pry bar or flat headed screw driver, pry the back cover from the front and lowly lift apart. It may be necessary to pry around the entire edge in order to remove the back cover.
단계 3  ¶
  • Using a pry bar or flat headed screw driver, pry the back cover from the front and lowly lift apart.
  • It may be necessary to pry around the entire edge in order to remove the back cover.
단계 4  ¶
Use tweezers to carefully unplug the wires connecting the speakers to the mother board. Use tweezers to carefully unplug the wires connecting the speakers to the mother board.
단계 4  ¶
  • Use tweezers to carefully unplug the wires connecting the speakers to the mother board.
단계 5  ¶
Locate the small tab located at the top, center of the motherboard. It connects the motherboard to the rest of the phone. Detach it using the tweezers. Carefully unplug the rectangular ribbon cable connection using tweezers. It should now be possible to lift the motherboard from the rest of the phone.
단계 5  ¶
  • Locate the small tab located at the top, center of the motherboard. It connects the motherboard to the rest of the phone. Detach it using the tweezers.
  • Carefully unplug the rectangular ribbon cable connection using tweezers.
  • It should now be possible to lift the motherboard from the rest of the phone.
