도움말
HP Mini 110-1046NR Fan Replacement
This guide details how to remove and replace the fan in an HP Mini 110.
  • 작성자: Amos Hine
  • 예상 시간 30 - 45 분
  • 난이도: 보통
If your computer is overheating, the most likely problem is a clogged fan. If your fan has stopped working or you are unable to clean it enough to allow it to work properly without removing it, this guide will be especially useful.
섹션
단계 1 Fan  ¶
Locate the two 3.8mm screws that hold the fan to the frame of the computer. You may have to hold wires out of the way to access one of the screws.
단계 1 Fan  ¶
  • Locate the two 3.8mm screws that hold the fan to the frame of the computer.
  • You may have to hold wires out of the way to access one of the screws.
  • Remove the screws with a Phillips PH1 screwdriver.
단계 2  ¶
Unplug the fan power cable by pushing the connector away from the receptacle with a pry stick and one finger (or two pry sticks). Lift the fan out of the computer.
단계 2  ¶
  • Unplug the fan power cable by pushing the connector away from the receptacle with a pry stick and one finger (or two pry sticks).
  • Lift the fan out of the computer.
