메인 콘텐츠로 스킵하기
도움말
Behringer Eurolive B212D Audio Amplification PCB Replacement
잠재적으로 위험한
잠재적으로 위험한
절차를 제대로 따르지 않을 경우 부상을 입을 수 있습니다. 주의를 요하며 모든 경고를 따라주십시오.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
헷갈리는 텍스트
헷갈리는 텍스트
해당 안내서의 어떤 텍스트는 헷갈리며, 중복되었거나 주제에서 벗어났습니다. 편집하여 명확하게 하여 주십시오!
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
Remove and replace the main electronics board in the speaker, the audio amplification PCB.
  • 작성자: gameslammer7
  • 예상 시간 45 분 - 1 시간
  • 난이도: 보통
The audio amplification PCB is the PCB which has the task of amplifying the B212D speaker's input signals.
단계 1 Audio Amplification PCB  ¶
Remove the 2 indicated flat head machine screws indicated using a #2 phillips head screwdriver. The small PCB could be removed for replacement at this point, but you can also just leave it attached to the audio amplification PCB as you remove other parts. The small PCB could be removed for replacement at this point, but you can also just leave it attached to the audio amplification PCB as you remove other parts.
  • Remove the 2 indicated flat head machine screws indicated using a #2 phillips head screwdriver.
  • The small PCB could be removed for replacement at this point, but you can also just leave it attached to the audio amplification PCB as you remove other parts.
단계 2  ¶
Remove the 2 indicated flat head machine screws using a #2 phillips head screwdriver. Remove and set aside the metal panel that was separating the small PCB from the audio amplification PCB. Remove and set aside the metal panel that was separating the small PCB from the audio amplification PCB.
단계 2  ¶
  • Remove the 2 indicated flat head machine screws using a #2 phillips head screwdriver.
  • Remove and set aside the metal panel that was separating the small PCB from the audio amplification PCB.
단계 3  ¶
Note the 4 large flat head machine screws which hold the clamps on the opposite side; remove them with a #2 phillips head screwdriver. The clamps are meant to hold the audio amplification PCB's IC's to the common heat sink; they ensure proper contact between the heat sink and the IC's through the ceramic thermal paste.
단계 3  ¶
  • Note the 4 large flat head machine screws which hold the clamps on the opposite side; remove them with a #2 phillips head screwdriver.
  • The clamps are meant to hold the audio amplification PCB's IC's to the common heat sink; they ensure proper contact between the heat sink and the IC's through the ceramic thermal paste.
단계 4  ¶
Note the 3 flat head machine screws holding the heat sink to the metal electronics box; remove them using a #2 phillips head screwdriver. It may be possible to leave this heat sink connected, but you will have to separate the heat sink from the IC's and be careful not to touch the ceramic thermal paste: its really hard to remove, even with soap!
단계 4  ¶
  • Note the 3 flat head machine screws holding the heat sink to the metal electronics box; remove them using a #2 phillips head screwdriver.
  • It may be possible to leave this heat sink connected, but you will have to separate the heat sink from the IC's and be careful not to touch the ceramic thermal paste: its really hard to remove, even with soap!
단계 5  ¶
Note the location of the 4 indicated machine screws which hold the audio amplification PCB to the metal electronics box; remove them using a #2 phillips head screwdriver. The screws are not actually attached in this photo; sorry!
단계 5  ¶
  • Note the location of the 4 indicated machine screws which hold the audio amplification PCB to the metal electronics box; remove them using a #2 phillips head screwdriver.
  • The screws are not actually attached in this photo; sorry!
단계 6  ¶
Remove the audio amplification PCB from the metal electronics box. If you haven't already, remove the heat sink from the IC's, being careful not to get any of the ceramic thermal paste on your skin, as it is difficult to remove, even with soap.
단계 6  ¶
  • Remove the audio amplification PCB from the metal electronics box.
  • If you haven't already, remove the heat sink from the IC's, being careful not to get any of the ceramic thermal paste on your skin, as it is difficult to remove, even with soap.
