도움말
Nokia 3360 Battery Replacement
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
Changing the Battery is easy -- no tools required.
단계 1 Battery  ¶
Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
단계 1 Battery  ¶
  • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
  • Lift the back plate off the phone.
단계 2  ¶
To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time. To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
단계 2  ¶
  • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
단계 3  ¶
Lift the battery out of the phone. Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
단계 3  ¶
  • Lift the battery out of the phone.
  • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
