도움말
iPhone 5s Vibrator Replacement
Use this guide to replace a non-functioning vibrator.
  • 작성자: Sam Goldheart
  • 예상 시간 45 분 - 2 시간
  • 난이도: 보통
Use this guide to restore silent rings to your iPhone 5s by replacing a non-functioning vibrator.
단계 1 Vibrator  ¶
Remove the following Phillips #000 screws from the vibrator bracket:
단계 1 Vibrator  ¶
  • Remove the following Phillips #000 screws from the vibrator bracket:
  • One 1.7 mm screw
  • One 2.5 mm screw
단계 2  ¶
With a set of tweezers, remove the vibrator bracket.
단계 2  ¶
  • With a set of tweezers, remove the vibrator bracket.
단계 3  ¶
Remove the 1.7 mm Phillips #000 screw securing the vibrator to the rear case. You'll have to hold the driver at a slight angle, be sure not to strip the screw as you remove it.
단계 3  ¶
  • Remove the 1.7 mm Phillips #000 screw securing the vibrator to the rear case.
  • You'll have to hold the driver at a slight angle, be sure not to strip the screw as you remove it.
단계 4  ¶
Use a set of tweezers to remove the vibrator from the rear case.
단계 4  ¶
  • Use a set of tweezers to remove the vibrator from the rear case.
