도움말
HP Pavilion 8775c Desktop Hard Drive Replacement
더 많은 이미지가 필요함
더 많은 이미지가 필요함
몇몇 추가 이미지는 해당 안내서의 절차를 아주 명백하게 만들 것입니다.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
Remove gray bezel Remove side panel Disconnect drives. Remove screws holding drive assembly in Remove screws holding drives in to assembly
  • 작성자: Bill Jacobs
  • 예상 시간 40 분 - 1 시간
  • 난이도: 보통
Guts of this desktop are hard to get at and around.
This guide lets you get at a lot of the parts in this non-intuitive desktop that you may wish to reseat or replace.
May apply to similar Pavilion desktops like the 8731c 8737c 8750c 8754c 8755c 8756c 8762c 8765c 8766c 8770c 8771c 8772c 8776c 8777c and 8785c
Where models differ, this HP article may help:
http://h10025.www1.hp.com/ewfrf/wc/docum...
단계 1 Hard Drive  ¶
없는 이미지
단계 1 Hard Drive  ¶
  • Before you open the case proper...First, remove the transparent gray front bezel (Plastic case cover, noobs) that is nested in the beige front bezel.
단계 2  ¶
없는 이미지
단계 2  ¶
  • Now open the case. Use the thumbscrews and slide the side of the computer back and lift it off to expose the inside.
단계 3  ¶
없는 이미지
단계 3  ¶
  • Note the large metal sleeve/caddy/assembly that holds all your drives as one big box. This box's front protrudes from out the front side. See its edges exposed in the area revealed by removing the transparent gray bezel.
  • Remove the three screws that secure the box/caddy assembly to the front of the case
단계 4  ¶
없는 이미지
단계 4  ¶
  • Remove all cables from all the drives (pay some attention to which cable went to which drive). Watch out for audio feed cables that may connect to the CD players.
  • Slide the drives and their assembly out the front. Pay attention to which side of the assembly faced inside the case towards the motherboard.
단계 5  ¶
없는 이미지
단계 5  ¶
  • Remove all the screws from all the drives on the side facing the motherboard. That way, if you need to replace any drives later you won't have to disconnect everything and remove the assembly, you can just slide out the one broken drive.
  • You'll want to make sure that both screws on the side facing you and not the motherboard are in place so it is held securely enough.
단계 6  ¶
없는 이미지
단계 6  ¶
  • Remove any screws holding the broken drive (CD or hard drive) into the assembly and remove and or replace the drive. (or don't, if data recovery was all you were doing, like me.)
단계 7  ¶
없는 이미지
단계 7  ¶
  • If you are doing more parts replacement (e.g. memory) you can make more room by removing the power supply with the four screws that secure it to the back of the case. (be sure to support it as you take the last screw out, right?)
  • If your're done, replace the drive assembly and reconnect the cables (don't forget the audio cables to the CD drives!)
  • Secure the three screws that hold the assembly to the front of the case.
  • Slide the case cover onto the side with the thumbscrews and replace the gray transparent bezel.
  • Post an article on iFixit next time you run into something pointlessly complicated like this so you can save a poor guy like me a lot of time when Google comes up empty.
