도움말
Archos 5 and 48 Teardown
분해도
분해도
분해도는 device의 내부를 보여주는 정보일 뿐 분해 설명서로 사용하면 안됩니다.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
The pictures below are from an Archos 5 or 48 device. Please note that this procedure requires you to be very careful and that it will void your warranty. Also, this document may not apply to your specific device model, so try it at your own risk.
단계 1 Archos 5 and 48 Teardown  ¶
The Front:
  • The Front:
단계 2  ¶
The Back: You can see three rubber pads under which you will find screws. The fourth screw is under the plastic arm. After you removed these four screws, you can easily pop the two plastic pieces on each side of the device.
단계 2  ¶
  • The Back: You can see three rubber pads under which you will find screws. The fourth screw is under the plastic arm. After you removed these four screws, you can easily pop the two plastic pieces on each side of the device.
단계 3  ¶
The sides: There are two screws on each corner (so eight screws in total), indicated by the red arrows on the picture below. The metal contraption on the first picture is the wifi antenna. The sides: There are two screws on each corner (so eight screws in total), indicated by the red arrows on the picture below. The metal contraption on the first picture is the wifi antenna.
단계 3  ¶
  • The sides: There are two screws on each corner (so eight screws in total), indicated by the red arrows on the picture below. The metal contraption on the first picture is the wifi antenna.
단계 4  ¶
After you remove these eight screws, you will be able to pull the screen away from the rest of the device. Tilt the small plastic strip on the connector to release the wire. Separate the screen.
단계 4  ¶
  • After you remove these eight screws, you will be able to pull the screen away from the rest of the device. Tilt the small plastic strip on the connector to release the wire. Separate the screen.
단계 5  ¶
Under the screen you will find the top of the motherboard. There are four screws holding the motherboard and the hard drive together. After you remove those, the back of the device will come off.
단계 5  ¶
  • Under the screen you will find the top of the motherboard. There are four screws holding the motherboard and the hard drive together. After you remove those, the back of the device will come off.
단계 6  ¶
You now have access to the hard drive. Read the page on how to access the hidden partition. You now have access to the hard drive. Read the page on how to access the hidden partition.
단계 6  ¶
  • You now have access to the hard drive. Read the page on how to access the hidden partition.
단계 7  ¶
This is the bottom of the motherboard, when the hard drive is disconnected.
단계 7  ¶
  • This is the bottom of the motherboard, when the hard drive is disconnected.
단계 8  ¶
Another picture of the motherboard, it's actually thinner than the hard drive.
단계 8  ¶
  • Another picture of the motherboard, it's actually thinner than the hard drive.
