메인 콘텐츠로 스킵하기
도움말
Morphy Richards Iron Teardown
분해도
분해도
분해도는 device의 내부를 보여주는 정보일 뿐 분해 설명서로 사용하면 안됩니다.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
단계 1 Morphy Richards Iron Teardown  ¶
This is the iron we will take apart.
  • This is the iron we will take apart.
단계 2  ¶
First remove the rear or the iron using the flathead screwdriver.
단계 2  ¶
  • First remove the rear or the iron using the flathead screwdriver.
단계 3  ¶
Next remove the cable bridge bracket.
단계 3  ¶
  • Next remove the cable bridge bracket.
단계 4  ¶
Next remove the screws from the base. (see arrows for location)
단계 4  ¶
  • Next remove the screws from the base. (see arrows for location)
단계 5  ¶
Next remove the screw the hold the top on.
단계 5  ¶
  • Next remove the screw the hold the top on.
단계 6  ¶
To free the long cable remove from terminal block at rear.
단계 6  ¶
  • To free the long cable remove from terminal block at rear.
단계 7  ¶
At the front of the iron pull out the buttons for the steam and water.
단계 7  ¶
  • At the front of the iron pull out the buttons for the steam and water.
단계 8  ¶
Next unclip the button holder (red circle) by undoing the screws (black circle)
단계 8  ¶
  • Next unclip the button holder (red circle) by undoing the screws (black circle)
단계 9  ¶
Next remove the bridge clip from the arrows position.
단계 9  ¶
  • Next remove the bridge clip from the arrows position.
단계 10  ¶
Next remove the inner button (black circle)
단계 10  ¶
  • Next remove the inner button (black circle)
  • Now remove the centre screw (red arrow)
단계 11  ¶
slide off the cable holder from the cable.
단계 11  ¶
  • slide off the cable holder from the cable.
단계 12  ¶
Disassemble the plug
단계 12  ¶
  • Disassemble the plug
  • First remove the casing.
  • Now remove the wires from the pins.
  • Next remove the pins.
단계 13  ¶
Remove front of the iron by undoing the screw  (arrow) by first taking off cover cap.
단계 13  ¶
  • Remove front of the iron by undoing the screw (arrow) by first taking off cover cap.
단계 14  ¶
Next take out round selector, this is simply clipped so can be pulled out with pliers.
단계 14  ¶
  • Next take out round selector, this is simply clipped so can be pulled out with pliers.
단계 15  ¶
Next remove the washer parts at the front of the iron.
단계 15  ¶
  • Next remove the washer parts at the front of the iron.
  • Take the tubing off.
단계 16  ¶
Remove the seals for the water pump.
단계 16  ¶
  • Remove the seals for the water pump.
  • Now take pumps out.
단계 17  ¶
Remove the screw (circled) this will lead to the separation of the base and the top.
단계 17  ¶
  • Remove the screw (circled) this will lead to the separation of the base and the top.
단계 18  ¶
Remove the top of the iron to reveal the under parts.
단계 18  ¶
  • Remove the top of the iron to reveal the under parts.
  • Now remove the rubber seals from the plate.
  • Take out the screws linking to the stainless steel base.
단계 19  ¶
Remove the terminal block from the wires.
단계 19  ¶
  • Remove the terminal block from the wires.
  • Next take off the black section of the iron.
단계 20  ¶
Now remove the screws from the steel base.
단계 20  ¶
  • Now remove the screws from the steel base.
단계 21  ¶
Next remove each individual part ( mostly wiring)
단계 21  ¶
  • Next remove each individual part ( mostly wiring)
단계 22  ¶
All parts at the end of the process.
단계 22  ¶
  • All parts at the end of the process.
