메인 콘텐츠로 스킵하기
도움말
HP Pavilion dv6-2158nr Hard Drive Replacement
마크업 사고
마크업 사고
해당 안내서는 더 나은 마크업이 필요합니다. 일부 마크업 주석의 편집 또는 작성을 도와주십시오!
Instructions to remove the Hard Drive from the HP Pavilion dv6-2158nr.
  • 작성자: Chad
  • 예상 시간 5 - 10 분
  • 난이도: 쉬움
All your files are stored on the hard drive. People usually replace them when they need more storage. Before delving into this guide, make sure your computer is unplugged and completely turned off.
섹션
도구
단계 1 Hard Drive  ¶
Use a Phillips #1 screwdriver to loosen the two 6mm captive screws that secure the hard drive port bezel cover to the computer. Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover. Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover.
단계 1 Hard Drive  ¶
  • Use a Phillips #1 screwdriver to loosen the two 6mm captive screws that secure the hard drive port bezel cover to the computer.
  • Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover.
단계 2  ¶
Use the Mylar tab to lift the hard drive up, and then slide out to release it from the hard drive bay. Use the Mylar tab to lift the hard drive up, and then slide out to release it from the hard drive bay.
단계 2  ¶
  • Use the Mylar tab to lift the hard drive up, and then slide out to release it from the hard drive bay.
단계 3  ¶
Disconnect the hard drive cable from the system board. Remove four 4mm screws from the hard drive case. There are two screws on each side of the hard drive.
단계 3  ¶
  • Disconnect the hard drive cable from the system board.
  • Remove four 4mm screws from the hard drive case.
  • There are two screws on each side of the hard drive.
