메인 콘텐츠로 스킵하기
도움말
JBL On Stage II Speakers Replacement
This will guide you through how to remove and replace the speakers within the device.
First, the device will need to be cracked open. After, you will remove the damaged speakers and replace them with new, working speakers.
단계 1 The Speakers  ¶
Separate speakers from their slots using a metal spudger. Careful, as this step may cause damage to the device.
단계 1 The Speakers  ¶
  • Separate speakers from their slots using a metal spudger.
  • Careful, as this step may cause damage to the device.
단계 2  ¶
Cut the black wire (leading to the speaker you are replacing) with a pair of wire cutters. Cut the red wire (leading to the speaker you are replacing) with a pair of wire cutters.
단계 2  ¶
  • Cut the black wire (leading to the speaker you are replacing) with a pair of wire cutters.
  • Cut the red wire (leading to the speaker you are replacing) with a pair of wire cutters.
  • Notice that two black wires and two red wires connect to the speaker, be sure to reattach both wires to the new speaker.
