메인 콘텐츠로 스킵하기
도움말
Xbox 360 E Button Board Replacement
Replace the button board on the Xbox 360 E.
  • 작성자: Jennifer
  • 예상 시간 30 분
  • 난이도: 보통
Use this guide if your eject or power buttons are not working and need to be replaced.
섹션
단계 1 Button Board  ¶
Rotate the front panel so you are looking at the inside of the piece. Unscrew the six 6 mm screws with the T6 Torx screwdriver. Carefully pull the green plate up and off to remove it.
단계 1 Button Board  ¶
  • Rotate the front panel so you are looking at the inside of the piece.
  • Unscrew the six 6 mm screws with the T6 Torx screwdriver.
  • Carefully pull the green plate up and off to remove it.
