메인 콘텐츠로 스킵하기
도움말
Memorex Mi3X Minimove iPod Adapter Replacement
iPod adapter not working? Device not being recognized by the boombox? This is a replacement guide for the Memorex Mi3X Minimove iPod Adapter.
  • 작성자: Brett Langlois
  • 예상 시간 30 - 45 분
  • 난이도: 어려움
You may find that the boombox is not recognizing or charging your iPod. This guide demonstrates how to replace the iPod adapter if your original adapter fails. It also involves extensive unscrewing and disassembly of the device.
단계 1 iPod Adapter  ¶
Be careful when removing the bottom panel. The plastic tab that runs alongside the right speaker between the upper brown radio motherboard and the lower green audio daughterboard may damage the device if the bottom panel is removed improperly. Remove the bottom panel of the boombox by carefully pulling the  panel straight backwards from the boombox until the boards are free. Remove the bottom panel of the boombox by carefully pulling the  panel straight backwards from the boombox until the boards are free.
단계 1 iPod Adapter  ¶
  • Be careful when removing the bottom panel. The plastic tab that runs alongside the right speaker between the upper brown radio motherboard and the lower green audio daughterboard may damage the device if the bottom panel is removed improperly.
  • Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
단계 2  ¶
Use a Phillips #1 screwdriver to remove the two 8 mm screws encasing the iPod adapter near the top of the device. Use a Phillips #1 screwdriver to remove the two 8 mm screws encasing the iPod adapter near the top of the device.
단계 2  ¶
  • Use a Phillips #1 screwdriver to remove the two 8 mm screws encasing the iPod adapter near the top of the device.
단계 3  ¶
Use moderate force to pry the plastic casing off with your finger while pushing with your thumb against the black, round capacitors. Use moderate force to pry the plastic casing off with your finger while pushing with your thumb against the black, round capacitors.
단계 3  ¶
  • Use moderate force to pry the plastic casing off with your finger while pushing with your thumb against the black, round capacitors.
단계 4  ¶
Follow the wires attaching to the iPod adapter and use the IC (Integrated Circuit) extractor to remove the indicated wire connectors from the motherboard. Pinch the IC extractor just under the top lip of the wire housing. Pinch the IC extractor just under the top lip of the wire housing.
단계 4  ¶
  • Follow the wires attaching to the iPod adapter and use the IC (Integrated Circuit) extractor to remove the indicated wire connectors from the motherboard.
  • Pinch the IC extractor just under the top lip of the wire housing.
단계 5  ¶
Going back to the small green daughterboard, unscrew the four 6 mm screws with a Phillips #1 screwdriver. Going back to the small green daughterboard, unscrew the four 6 mm screws with a Phillips #1 screwdriver.
단계 5  ¶
  • Going back to the small green daughterboard, unscrew the four 6 mm screws with a Phillips #1 screwdriver.
단계 6  ¶
Remove the iPod adapter by sliding it out of the slot.
단계 6  ¶
  • Remove the iPod adapter by sliding it out of the slot.
