도움말
Professional Series PS77401 Chassis Replacement
한 단계 누락
한 단계 누락
이런! 해당 안내서는 현재 몇몇 중요한 단계가 빠져 있습니다.
This guide will cover replacing the chassis of a Professional Series PS77401 toaster. Dis-assembly of most of the major components on the toaster is required.
  • 작성자: Kevin
  • 예상 시간 30 - 45 분
  • 난이도: 보통
This guide will show how to remove the chassis from a Professional Series PS77401 toaster. The chassis may be damaged from a high height drop and may need replacing to allow even toasting. This guide is not a repair guide and requires a replacement toaster chassis.
단계 1 Chassis  ¶
Locate the small circuit board attached to the base of the toaster. To remove the circuit board, pull apart the two side tabs while releasing the middle tab simultaneously. Pull the circuit board out of the slot.
단계 1 Chassis  ¶
  • Locate the small circuit board attached to the base of the toaster.
  • To remove the circuit board, pull apart the two side tabs while releasing the middle tab simultaneously.
  • Pull the circuit board out of the slot.
단계 2  ¶
Using a Phillips #2 screwdriver, remove the front two 8mm screws attaching the chassis to the base. Flip the toaster around and proceed to remove the two remaining 8mm screws. The toaster chassis should now only be connected to the base via wiring.
단계 2  ¶
  • Using a Phillips #2 screwdriver, remove the front two 8mm screws attaching the chassis to the base.
  • Flip the toaster around and proceed to remove the two remaining 8mm screws.
  • The toaster chassis should now only be connected to the base via wiring.
단계 3  ¶
There are two phillips 8mm head screws holding the power cable to the base.
단계 3  ¶
  • There are two phillips 8mm head screws holding the power cable to the base.
  • Remove these screws to release the power cable.
단계 4  ¶
The following wires must be disconnected to be able to remove the chassis: Blue x2, White x2, Bronze x1 Disconnecting the cables in the middle is recommended to be able to reconnect new wires from a new chassis easily.
단계 4  ¶
  • The following wires must be disconnected to be able to remove the chassis: Blue x2, White x2, Bronze x1
  • Disconnecting the cables in the middle is recommended to be able to reconnect new wires from a new chassis easily.
