도움말
Mr. Coffee DW13 Tubing Replacement
This guide will show you how to replace the white tubing in the base of your coffee maker that could be the reason it is leaking.
  • 작성자: Kinsie Ward
  • 예상 시간 10 분
  • 난이도: 쉬움
Then you will remove the base of the coffee maker, a couple small wires and with a little tug the tubing will pop right out.
단계 1 Tubing  ¶
Identify and remove the two 13mm screws securing the silver support bracket using a phillips head screw driver. Identify and remove the two 13mm screws securing the silver support bracket using a phillips head screw driver.
단계 1 Tubing  ¶
  • Identify and remove the two 13mm screws securing the silver support bracket using a phillips head screw driver.
단계 2  ¶
Gently lift the silver support bracket freeing the heating plate from the heating coil.
단계 2  ¶
  • Gently lift the silver support bracket freeing the heating plate from the heating coil.
단계 3  ¶
Use pliers to pinch and loosen the crimps. Use pliers to pinch and loosen the crimps.
단계 3  ¶
  • Use pliers to pinch and loosen the crimps.
단계 4  ¶
Once the crimps are loosened, slide them down the tubing.
단계 4  ¶
  • Once the crimps are loosened, slide them down the tubing.
단계 5  ¶
Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling  apart. Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling  apart.
단계 5  ¶
  • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
단계 6  ¶
Gently pull on plastic tubing, freeing it from the coffee maker One of the tubes has a red ball check valve in the middle. Be sure to note which hole it connects to. One of the tubes has a red ball check valve in the middle. Be sure to note which hole it connects to.
단계 6  ¶
  • Gently pull on plastic tubing, freeing it from the coffee maker
  • One of the tubes has a red ball check valve in the middle. Be sure to note which hole it connects to.
