도움말
Sony BDP-S1 Optical Drive Motor Replacement
한 단계 누락
한 단계 누락
이런! 해당 안내서는 현재 몇몇 중요한 단계가 빠져 있습니다.
Replace the motor that spins the disc.
  • 작성자: Sam
  • 예상 시간 25 - 35 분
  • 난이도: 보통
Open up the optical drive and take it apart until you get to the motor. This guide is a bit more difficult than simply unscrewing, but definitely doable. Also, you get to see the inside of the optical drive, which is pretty cool.
단계 1 Optical Drive Motor  ¶
Set aside the rest of the blu ray player; the only part you will need for this guide is the optical drive.
  • Set aside the rest of the blu ray player; the only part you will need for this guide is the optical drive.
단계 2  ¶
Remove the four 10mm silver screws on the bottom of the optical drive. Remove the 10mm silver screw on each side of the optical drive. Remove the single 6mm silver screw on the top of the optical drive.
단계 2  ¶
  • Remove the four 10mm silver screws on the bottom of the optical drive.
  • Remove the 10mm silver screw on each side of the optical drive.
  • Remove the single 6mm silver screw on the top of the optical drive.
단계 3  ¶
Any tape or foil strips need to be removed or cut before the drive can be opened (look at first image for example). Pull off the bottom metal panel of the optical drive. You will see the main circuit board underneath. Pull off the bottom metal panel of the optical drive. You will see the main circuit board underneath.
단계 3  ¶
  • Any tape or foil strips need to be removed or cut before the drive can be opened (look at first image for example).
  • Pull off the bottom metal panel of the optical drive. You will see the main circuit board underneath.
단계 4  ¶
Remove the two, 20mm silver screws holding the circuit board in place. Before removing the circuit board, you will need to disconnect the blue ribbon cable, two orange ribbon cables, and a small connector (look at second image for where the small connector is). The orange ribbon cables are held in place by a small locking mechanism. Lift the small brown tabs for easy disconnection.
단계 4  ¶
  • Remove the two, 20mm silver screws holding the circuit board in place.
  • Before removing the circuit board, you will need to disconnect the blue ribbon cable, two orange ribbon cables, and a small connector (look at second image for where the small connector is).
  • The orange ribbon cables are held in place by a small locking mechanism. Lift the small brown tabs for easy disconnection.
단계 5  ¶
Slowly lift up the circuit board. Make sure to disconnect the connector and ribbon cable on the underside of the circuit board before fulling removing it. Slowly lift up the circuit board. Make sure to disconnect the connector and ribbon cable on the underside of the circuit board before fulling removing it.
단계 5  ¶
  • Slowly lift up the circuit board. Make sure to disconnect the connector and ribbon cable on the underside of the circuit board before fulling removing it.
단계 6  ¶
Now you can see the inside of the optical drive. The motor is held in by three small 5mm silver screws. Remove them. Now you can see the inside of the optical drive. The motor is held in by three small 5mm silver screws. Remove them.
단계 6  ¶
  • Now you can see the inside of the optical drive. The motor is held in by three small 5mm silver screws. Remove them.
단계 7  ¶
Lift up the motor and replace it with a new one. Now you just need to put it back together! Lift up the motor and replace it with a new one. Now you just need to put it back together!
단계 7  ¶
  • Lift up the motor and replace it with a new one. Now you just need to put it back together!
