도움말
iPhone 5c Lightning Connector Assembly Replacement
Replace the Lightning connector assembly in your iPhone 5c.
Use this guide to replace the Lightning connector and audio port cable in your iPhone 5c.
You can also use this guide for reference when replacing the microphone gasket.
단계 1 Lightning Connector Assembly  ¶
Use a plastic opening tool to peel the home button spring contact cable up from the speaker enclosure. Use a plastic opening tool to peel the home button spring contact cable up from the speaker enclosure.
  • Use a plastic opening tool to peel the home button spring contact cable up from the speaker enclosure.
단계 2  ¶
Remove the following screws securing the speaker enclosure to the rear case:
단계 2  ¶
  • Remove the following screws securing the speaker enclosure to the rear case:
  • Two 2.7 mm Phillips #000 screws
  • One 2.2 mm Phillips #000 screw
단계 3  ¶
Use the flat end of a spudger to gently pry the speaker enclosure up from the rear case. Use the flat end of a spudger to gently pry the speaker enclosure up from the rear case.
단계 3  ¶
  • Use the flat end of a spudger to gently pry the speaker enclosure up from the rear case.
단계 4  ¶
Remove the speaker enclosure. Be careful not to snag it on the antenna cable. Remove the speaker enclosure. Be careful not to snag it on the antenna cable.
단계 4  ¶
  • Remove the speaker enclosure. Be careful not to snag it on the antenna cable.
단계 5  ¶
The far right screw hole on the speaker has a contact bracket wrapped around it. This small part may fall off unexpectedly,  so it's best to remove it and note the orientation for reassembly. The flat portion of the contact clip should rest against the speaker, as shown.
단계 5  ¶
  • The far right screw hole on the speaker has a contact bracket wrapped around it. This small part may fall off unexpectedly, so it's best to remove it and note the orientation for reassembly.
  • The flat portion of the contact clip should rest against the speaker, as shown.
  • The alignment bracket on the far end of the speaker assembly is adhered, but may fall off if handled aggressively.
  • The angled end should face up and line up with the outside edge of the speaker.
단계 6  ¶
Use a plastic opening tool to disconnect the Lightning connector ribbon cable from its socket on the logic board.
단계 6  ¶
  • Use a plastic opening tool to disconnect the Lightning connector ribbon cable from its socket on the logic board.
단계 7  ¶
The Lightning connector cable is lightly adhered to a shield on the logic board. Use the flat end of a spudger to gently peel the cable up. The Lightning connector cable is lightly adhered to a shield on the logic board. Use the flat end of a spudger to gently peel the cable up.
단계 7  ¶
  • The Lightning connector cable is lightly adhered to a shield on the logic board. Use the flat end of a spudger to gently peel the cable up.
단계 8  ¶
Disconnect the cellular antenna connector from the base of the logic board.
단계 8  ¶
  • Disconnect the cellular antenna connector from the base of the logic board.
단계 9  ¶
Remove the following screws securing the Lightning connector to the rear case:
단계 9  ¶
  • Remove the following screws securing the Lightning connector to the rear case:
  • Two 3.4 mm Phillips #000 screws
  • One 2.7 mm Phillips #000 screw
단계 10  ¶
Gently peel the Lightning connector assembly up from the rear case. Gently peel the Lightning connector assembly up from the rear case.
단계 10  ¶
  • Gently peel the Lightning connector assembly up from the rear case.
단계 11  ¶
You may need to use the flat end of a spudger to completely free the assembly. You may need to use the flat end of a spudger to completely free the assembly.
단계 11  ¶
  • You may need to use the flat end of a spudger to completely free the assembly.
단계 12  ¶
Remove the Lightning connector assembly. There is a small rubber gasket attached to the microphone. Be sure to transfer it to the new assembly.
단계 12  ¶
  • Remove the Lightning connector assembly.
  • There is a small rubber gasket attached to the microphone. Be sure to transfer it to the new assembly.
