도움말
HP PSC 2355 Button Panel Replacement
This replacement guide demonstrates how to replace the button panel on the HP PSC 2355.
  • 작성자: Patricia
  • 예상 시간 10 분
  • 난이도: 보통
A defective button pad is is not difficult to replace with just a couple tools.
섹션
도구
단계 1 Button Panel  ¶
Once you have removed the scanner lid, locate the finger notch on inside the top left half of the bezel (control) panel.
단계 1 Button Panel  ¶
  • Once you have removed the scanner lid, locate the finger notch on inside the top left half of the bezel (control) panel.
단계 2  ¶
Place your index finger in the notch and lift up to unsnap the panel.
단계 2  ¶
  • Place your index finger in the notch and lift up to unsnap the panel.
  • Set panel cover aside.
단계 3  ¶
Use a T9 torx screwdriver to remove the 0.9 cm screw.
단계 3  ¶
  • Use a T9 torx screwdriver to remove the 0.9 cm screw.
단계 4  ¶
From the front of the printer, remove the button panel by pulling it towards you while slightly lifting it up.
단계 4  ¶
  • From the front of the printer, remove the button panel by pulling it towards you while slightly lifting it up.
단계 5  ¶
Disconnect the white ribbon cable by grasping it between your thumb and index finger.
단계 5  ¶
  • Disconnect the white ribbon cable by grasping it between your thumb and index finger.
  • Gently pull to release the ribbon from the green circuit board
단계 6  ¶
Next, use the flat end of a spudger to pry loose the flat ribbon computer cable by the plastic connection end and carefully separate it from the prongs on the button panel.
단계 6  ¶
  • Next, use the flat end of a spudger to pry loose the flat ribbon computer cable by the plastic connection end and carefully separate it from the prongs on the button panel.
  • The entire button panel should now be completely disconnected from the printer.
단계 7  ¶
Lay the panel on a flat surface with the backside facing up.
단계 7  ¶
  • Lay the panel on a flat surface with the backside facing up.
  • Using a T9 torx screwdriver, remove all six 0.7 cm silver screws from the off-white plastic panel.
단계 8  ¶
Gently lift the button panel off the plastic backing with rubber button mat.
단계 8  ¶
  • Gently lift the button panel off the plastic backing with rubber button mat.
단계 9  ¶
Be careful not to lift out and lose the two clear plastic panel separators (these are not fastened to the panel but can easily fall out of the panel if tilted). These are two small plastic parts that sit near the top right and left portions of the panel.
단계 9  ¶
  • Be careful not to lift out and lose the two clear plastic panel separators (these are not fastened to the panel but can easily fall out of the panel if tilted). These are two small plastic parts that sit near the top right and left portions of the panel.
  • Insert your new button panel. To reassemble your printer, follow these instructions in reverse order.
