도움말
ChefsChoice M677 Control Switch Replacement
마크업 사고
마크업 사고
해당 안내서는 더 나은 마크업이 필요합니다. 일부 마크업 주석의 편집 또는 작성을 도와주십시오!
This guide shows how to replace the Control Switch unit for the Chef'sChoice® Model 677 Cordless Kettle.
This guide will walk you through the following steps:
  • Removing the bottom of the kettle
  • Locating and identifying the internal components
  • Disconnecting the wiring from the internal components
  • Removing the kettle power supply
  • Removing the kettle control switch
Reassembly is as simple as reversing the steps!
단계 1 Control Switch  ¶
FIRST IMAGE: Remove the power supply. Align the kettle as shown, with the handle to your right. Use the 7/32" nut driver to remove the 7/32" nut from the stud that is located clockwise from where the power supply was attached. Use tweezers to remove the split-ring lock washer located under the nut.
  • FIRST IMAGE: Remove the power supply. Align the kettle as shown, with the handle to your right. Use the 7/32" nut driver to remove the 7/32" nut from the stud that is located clockwise from where the power supply was attached.
  • Use tweezers to remove the split-ring lock washer located under the nut.
  • SECOND IMAGE: Roll the kettle over so the handle is now on your left. Use the 7/32" nut driver to remove the 7/32" nut from the final stud, which is now located counter-clockwise from where the power supply was attached.
단계 2  ¶
Grasp the control switch with one hand and the kettle with the other. Gently rock the control switch while simultaneously pulling it away from the bottom of the kettle. Pull the switch completely off the kettle.
단계 2  ¶
  • Grasp the control switch with one hand and the kettle with the other.
  • Gently rock the control switch while simultaneously pulling it away from the bottom of the kettle.
  • Pull the switch completely off the kettle.
단계 3  ¶
This image shows the alignment of various kettle parts.
단계 3  ¶
  • This image shows the alignment of various kettle parts.
  • The yellow arrows show how the studs align with the switch brackets.
  • The blue arrow shows how the steam tube aligns with the steam chamber on the switch thermostat.
