도움말
JBL On Stage II Auxiliary Jack Replacement
추천 학생 안내서
추천 학생 안내서
해당 안내서는 저희 멋진 학생들의 노력으로 만들어졌으며 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
This will guide you through the process of removing and replacing the auxiliary jack.
To complete this guide, you will need to disassemble your device and use a soldering iron to replace the jack.
단계 1 Auxiliary Jack  ¶
Turn the device upside down. Desolder the back lead for the auxiliary port that is circled. Heat the lead until the solder melts.
  • Turn the device upside down.
  • Desolder the back lead for the auxiliary port that is circled.
  • Heat the lead until the solder melts.
  • Remove the solder with the solder pump.
  • For help with soldering view the iFixit soldering guide
단계 2  ¶
Repeat step 13 for the other two leads.
단계 2  ¶
  • Repeat step 13 for the other two leads.
단계 3  ¶
Turn your device right-side up.
단계 3  ¶
  • Turn your device right-side up.
  • Remove the auxiliary jack.
