메인 콘텐츠로 스킵하기
도움말
Sony Xperia Z Front Facing Camera Replacement
Replace your front-facing camera of your Sony Xperia Z.
  • 작성자: Emily Holland
  • 예상 시간 25 - 30 분
  • 난이도: 어려움
This guide will lead you through the necessary steps to replace your front-facing camera of the Sony Xperia Z.
단계 1 Front Facing Camera  ¶
With the plastic opening tool, gently pry the red tape away from motherboard. This pop connector is located at the top right corner of the phone. Using your fingers, gently pull up on the pop connector to remove the front camera. The front camera piece should lift out effortlessly.
  • With the plastic opening tool, gently pry the red tape away from motherboard. This pop connector is located at the top right corner of the phone.
  • Using your fingers, gently pull up on the pop connector to remove the front camera. The front camera piece should lift out effortlessly.
