메인 콘텐츠로 스킵하기
도움말
Mr. Coffee DW13 Base Removal
This will teach you how to remove the base of the coffeemaker, exposing all of the inner parts.
  • 작성자: Tess Bradley
  • 예상 시간 5 분
  • 난이도: 쉬움
In order to remove the base of your Mr. Coffee DW13, you will need to position the coffee machine so that the bottom is facing you. After, you will remove eight screws and gently lift the cover from the base.
단계 1 Base  ¶
Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean. Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
단계 1 Base  ¶
  • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
  • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
단계 2  ¶
Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver. Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
단계 2  ¶
  • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
단계 3  ¶
Gently lift the base cover to expose the inside of the coffee machine.
단계 3  ¶
  • Gently lift the base cover to expose the inside of the coffee machine.
